SOS after successful porting
zdorward
man this whole process has been brutal. I ported successfully (got the welcome text from public) and now I just have SOS and can't text or call at all. I've done everything from rebooting to resetting network settings, and I even bought a new E sim. nothing working. I've toggled on and off the line, airplane mode, everything.
2 REPLIES 2
CSA_PM
Customer Support Agent
We appreciate your escalation. An agent is already assisting the customer and will ensure they receive the support they need.
hi @zdorward
you got the welcome email might not mean the port was done.  You replied Yes to your old provider to approve the port yet?
if you did,   please make sure your old sim card is removed (or if esim, please disable it).  Then check if PM sim is enabled and set as Primary
next, reboot phone and click Reset network settings.  You should see the phone showing connected to Public Mobile.  Test again
