02-28-2018 06:19 PM - edited 01-04-2022 03:38 PM
03-02-2018 11:53 AM - edited 03-02-2018 12:43 PM
I wrote:
For MMS after i deleted APN few times and added finally works well.
For SMS meanwhile, i tested for normal numbers to send/receive the sms for all service provider from that country.
The problem is only for short numbers like: <country code> *1234 for receive SMS
03-02-2018 11:39 AM - edited 03-02-2018 11:40 AM
I'd suggest trying SIM in a different phone first
It's unlikely a SIM issue to send SMS to Country X since you also having issues sending MMS in Canada
@sophitechnicusñwrote:On the some phone before all was working well.
I know this post, thanks.
The settings are ok (https://apn-canada.gishan.net/settings/1167_15_public_mobile_apn_settings_for_asus_zenfone_2_laser.p...)
I don't try to send in USA but to another country is working.
The data is working, of course the data is on.
The phone is Asus zenfone 2.
03-02-2018 11:25 AM - edited 03-02-2018 12:10 PM
To summarize:
* MMS works fine when you're in Canada.
* short code SMS to one specific country doesn't work when you're in Canada?
* regular SMS to/from Canadian numbers are working fine when you're in Canada?
* regular SMS to/from international numbers are working fine when you're in Canada?
* short code SMS working fine for Canadian/US numbers when you're in Canada?
This is a very special scenario and unlikely it will be supported by Telus.
03-02-2018 08:10 AM
Hello,
Doesn't work.
For SMS meanwhile, i tested send/receive the sms for all service provider from that country.
Thanks for all.
02-28-2018 08:27 PM
You could try this procedure to reset SMS:
02-28-2018 08:21 PM
Isn't first time when i deleted the APN and i added.
Now , i deleted and added. The MMS is working.
The SMS still have the issue. ...............
02-28-2018 08:01 PM
First of all, i'm in Canada.
First, the SMS outside from Canada isn't receive.
Second, the MMS sended inside of Canada isn't delivered(i don't try outside)
02-28-2018 07:52 PM
from what i remember common trouble shooting is to install a new/different sms app. assuming you alreasy powered cycled your phone.
I know occasioanlly (happened twice) that i had issues sending mms but the next day all was working fine.
this also sometimes helps
MMS APN | Set APN type to “default,mms,supl” |
possibly a network settings reset (not factory reset) then reenter apn
but just to be clear everything was woking before and then today/yesterday they stopped.
not sure what else to suggest sorry, hopefully someone else might have osme other ideas
02-28-2018 07:52 PM - edited 02-28-2018 07:53 PM
Your posts are still confusing.
So, you are in Canada and are sending a message to Turkey (since you didn't provide proper information I'm picking a country at random...)? But the person in Turkey doesn't get your SMS nor MMS?
Any updates on your or the recipient's phone?
Have you rebooted your phone?
Have you tried a different messaging app? (Textra is my personal favorite, but other's have had good results with Google messages.)
Any changes in policies on the recipients side? (Government, carrier?)
02-28-2018 07:41 PM
02-28-2018 07:33 PM
this is a good guide for setting up apns https://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Setting-up-Data-APN-on-your-phone/ta-p...
when you say sms are not received are you sending sms from inside canada to friends in a different country? or are you in a different country like USA
does data on your phone work? is data on? what phone do you have?
02-28-2018 07:23 PM
The SMS aren't received outside of Canada.
The MMS isn't send from my phone(i want to send in Canada not outside)
For MMS
APN Settings:
APN: sp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMS proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
Authentication type: Not set
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: None
MVNO value: Not set
02-28-2018 07:04 PM
A little more info migh be good.
but sms should be received anywhere in canada or usa. anywhere else you do not have service
mms need apn to se set correctly and data to be on to be sent and received
sending mms in usa does not work at all. not sire about receiving mms.
02-28-2018 06:58 PM
Were you roaming in the same country both times? I think USA roaming allows incoming SMS, but other countries do not.
MMS should work in Canada if your APN settings are correct. Have you checked that recently?
