SMS Offer
Sweet-Tangerine
Hi there,
I just accepted an offer sent to me via text for 20 GB of 4G data for $27. Could you please confirm if this is just an add-on to my existing plan, or if the $27 is a new plan that includes calls/texts?
Thank you 🙂
DennyCrane
I don't know why after all this time they haven't figured out that they should clarify this in the text offer. Yes it includes all of the above. No they don't say it for some reason.
eddieO
@Sweet-Tangerine it's a pretty good deal but just be aware that if you switch to it you will very likely be unable to switch back to your old plan depending on what it is, especially the $15 plans which are no longer available
hi @Sweet-Tangerine not add-on to existing plan, it is a new plan you will change to if you accept
@Sweet-Tangerine the $27 plan is a new plan and NOT add-on .  If will kick in on your next renewal if you reply Yes
