08-21-2022 12:15 AM
Just transferred from another provider and the Public Mobile account shows active but the phone is showing SIM not activated?!
08-21-2022 10:35 AM
@Kkristani - in addition to other's suggestion, you may also try one or more of the below:
08-21-2022 08:54 AM
Did you check to be sure your phone is unlocked from your old provider? Some phones are locked and cannot be used with alternate providers until they have been unlocked. You can also check on public mobile website if your phone is compatible with their service.
08-21-2022 02:19 AM
Did you try login to your account to see if it is Active?
If not then the porting may not be completed from your old carrier. Most new members forget to leave the old SIM in the phone and wait to reply to the text confirming you are porting over to PM. There is a 90 minute window for your to reply.
Could you please let us know if your account is Active and did you reply to the text so we can help further.
08-21-2022 12:27 AM
@Kkristani did you try reboot the phone?
do you have another phone to test the sim card ?
if it still the same after a reboot or tested on a second device, it could be sim provisioning issue. It is an easy fix for PM, but you just need to open ticket with PM support
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
