*SIM card does not allow access to Public mobile* New Walmart card. New activation today. ideas?
dingaling
New Walmart card reads IMEI OK. Just activated. No Rx bars on phone. Message: SIM card does not allow access to Public Mobile. No service. Please help.
8 REPLIES 8
CS_Agent
Customer Support Agent
Hello dingaling,
Thank you for reaching out to us.
If you are still experiencing "No Service" issue, please send us a Private message for further assistance.
We are looking forward to your response.
Cheers
Abdoulaye
dingaling
Hi galaxy 17,
If you can get an IMEI by dialing *#06*, your SIM should be good. If you can't, your SIM may not be inserted correctly. Or it may be damaged. If you do get an IMEI, by turning off, then on, your phone should activate. Best of luck.
dingaling
Hi mimmo,
I re-seated the SIM and booted my HTC One-V. It worked immediately. I am very pleased with the service at this early date. Thank you for your advice.
will13am
This is a strange outcome.  I suggest sending a private message to the moderator team and have them investigate the activation.  The moderator team can be reached via private message using this link.  Refer to the following link for information on contacting the moderator team.  Good luck and welcome to this service.
http://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Updated-Contacting-our-Community-Modera...
dingaling
If your phone can read the IMEI using *#06# the SIM card should be compatible. In my case. I re-seated the SIM card, in the correct position of course, and then re-booted my phone. My HTC ONE-V works great!
dingaling
I was able to solve my own problem by re-booting the phone. It works GREAT!!
mimmo
@dingaling what phone are you using? Can you try sim in another phone?
galaxy17
Hi. I have a very similar issue. I received a SIM in the mail, followed activation yesterday and paid for a plan, the phone looks compatible (HTC 10) but says the SIM card does not allow to connect to this network (when manually forcing a connect to public mobile).
Any ideas? Cheers
