10-31-2016 04:26 AM - edited 01-04-2022 03:50 PM
11-06-2016 03:15 AM
11-04-2016 12:19 PM
11-04-2016 02:56 AM
@daredogg Bro the incoming calls did "kick in" at around noon when i heard the phone start to ring. Yay, finally after 3 days my problem is gone! Poof! Gone! All is good, i can move on with my life. Now i can be Batman.
11-03-2016 04:05 PM
Hopefully it's only a manner of time @Lteguy that the calling "kicks in". If by tomorrow it's still not working, I'd suggest you contact one of the moderators again.
One good thing about the problems you've experienced... now you can be the guy to tell everyone what not to do, and get lots of bravos doing it!
11-03-2016 08:55 AM
I started being able to receive text messages yesterday. However my incoming calls still doesnt work. I dont owe Mobilicity any money is that considered good standing? Im not part of any contract and when i called Mobilicity to get my account number yesterday i explained to them i was going to port my number and they didnt tell me anything about being an active customer.
11-01-2016 04:20 PM
@Lteguy just to be clear--you said they cut your service off and then you activated the SIM? Is that correct? If so, this is 100% the reason why your port has failed. You have to be an active customer, in good standing, with your previous provider in order to port your number out. This is industry standard in Canada. If this is the case, you will need to contact Mobilicity and reactivate your line on the cheapest plan they will let you activate, and then come back and try the port request again.
11-01-2016 04:19 PM
Good afternoon @Lteguy
Thank you for reaching out to us !
Have you followed the suggestion mentioned above ? If not, please send your info to one of us via private message. We'll get back to you shortly 🙂
Mary
11-01-2016 11:55 AM
@Lteguy contact Shazia_K by private message (see message above). Port shouldn't take more than 24 hours, so it's likely the port is stuck and needs to be pushed through.
11-01-2016 02:56 AM - edited 11-01-2016 03:12 AM
Its been 24 hours exact and incoming calls im still not getting. My Mobilicity contract ended on Oct 28 although they didnt cut my service till Oct 30 (last night) hence me activating my PM sim. Thanks for the welcome ya'll glad to see so many replies for troubleshooting my lil dilemma. Im gona wait a couple more days and let Public Mobile network to do its porting thing and hopefully itll sort itself out if not ill be coming thru again just a couple days.
10-31-2016 02:01 PM
Thanks @Shazia_K. My problem has been resolved.
10-31-2016 11:00 AM
Hello all,
I'm sorry to hear that some of you are having issues with your porting requests,
If this is the case, please send me a private message with the following:
-Public Mobile SIM card #
-Number you wish to port
-Account number with old provider
Thanks,
Shazia
10-31-2016 10:06 AM
10-31-2016 06:25 AM
also try power cycling your phone it might help. when porting a number sending call is faster than receiving calls. it is not instant, I recal being told it can take upto several hours (not sure the exact max time). from my experience (4 lines)it is all good within 30- 40 minutes, if not faster. dont worry, if it is still not working after several hours contact one of the moderators. Welcome to PM
10-31-2016 06:06 AM
@Lteguy Some carriers take longer than others, but the symptoms you're describing are because the port hasn't completed yet. Whether it's stuck or not, that depends on when you did initiated it. What time did you port your number at?
10-31-2016 04:45 AM
Your phone number has not been ported yet and any incoming communications are still going to Mobilicity. Contunue using your Mobilicity service until your phone number is transfered.
