Data limit for MMS ?
10-31-2016 12:47 AM - edited 01-04-2022 03:50 PM
I sent a couple of 5MB pictures and triggered a data usage when i checked my usage in my PM profile.
App such as Tetra can compress the pictures to within the carrier limitations.
Service
10-31-2016 12:06 PM
Thanks for the update, @fathom
10-31-2016 11:18 AM
Did a quick test sending to and from a iPhone 5s on Telus.
Using both 1Mb limit and unlimited size, the pictures I sent came out compressed at just under 1Mb
And receiving from iPhone on Telus was the same thing.
Completely non scientific but I guess Telus allows up to 1Mb is the answer.
10-31-2016 01:52 AM - edited 10-31-2016 01:53 AM
Interesting question. This page makes it sound like it may be phone and/or app dependent, rather than a network limit: http://www.telus.com/en/bc/support/article/photo-video-messaging. (EDIT: it says "For file size limit, maximum number of attachments, picture quality, and video length, consult the user guide for your phone")
@fathom did you discover anything interesting checking the usage? Sending MMS does not count against your plan or add-on data buckets. Did the 5MB pictures go through? Do you know if they were resized at all?
10-31-2016 12:50 AM
It's a good question. I guess the answer is no. Hope moderators can answer this question tomorrow. @Mary_M
