SIM card activated but no service
4ndr3wch4n
I'm pretty sure my SIM card is activated but I have no service still. It shows that it has been topped on in the overview and I can also login and see all the information using my email and password, but I still have no service. Can anyone help?
16 REPLIES 16
jgorman
Welcome to saving money with great service and a great plan😀👍
jgorman
Welcome to PM😀
Kaiyo
@4ndr3wch4n wrote:
SOLVED: Sorry for the inconvenience. I forgot to register with public mobile by chaning my network operator.Smiley Frustrated
Normally after a reboot the phone would auto detect and change it.
4ndr3wch4n
jgorman
jgorman
It can sometimes take up to 24 hours for the port.
Nothing works text calls incoming outgoing data?
Does it say Public Mobile?
4ndr3wch4n
It's a OnePlus One, so yeah, it is unlocked. Also I did the port about maybe 2 hours ago.
jgorman
And what time did you do the port?
jgorman
What kind of phone do you have?
It's unlocked?
4ndr3wch4n
I tried, it does not work. No service anymore after porting.
jgorman
Try putting in your old sim see if that is still working.
Kaiyo
@jgorman wrote:
Are your APN settings set up?
APN only has to do with data
jgorman
Kaiyo
Did you try swapping back anyways? It could still be functional.
You should private message one of the mod. The information you should include in your message:
http://productioncommunity.publicmobile.ca/t5/Announcements/Information-required-before-sending-a-me...
4ndr3wch4n
I tried, it didn't do anything. I can't swap back to my old SIM card either because I transferred the number over here.
Kaiyo
Try rebooting your phone.
