SIM Card order: 2xxxxx
brownkm
Hi, I ordered this on April 10 and I'm still waiting. Wondering the status?
I second this, whether you pick up or get it shipped it is much quicker. If you go this route you can reach out to a CSA for a refund or have them put the cost of the sim from PM into your available balance.
Meow
It usually takes 2-3 weeks (or longer - covid is excuse) to receive it.
You can inquire with the agent but I bet you will get the same answer. SIMs are sent by regular mail so I doubt there is a tracking umber.
hairbag1
If you're in GTA, get ahold of these folks...
https://canadiancellsupplies.com/collections/latest-products/products/public-mobile-multi-sim-card-3...
SIM is only $3 and they offer curbside pickup.
@brownkm   sim card order from PM online could take as many as 3 weeks.  Yes it is slow.  If you need one urgently, check mobile stores around you.  If you activate with them, they will likely give you the sim for free anyway
to check the status of your sim order, please open ticket with PM Support with direct message
