SIM Card Activation Issues
06-28-2019 05:40 PM - edited 01-05-2022 05:38 AM
Hello,
I received the SIM card 2 days ago. We went through the steps to activate the SIM card. We made it through all of the steps; however, when it came time to sign-up for the plan and process payment with my credit card, I received an error message saying something went wrong and to start over. But, when I try to start over, whenever I enter in the SIM card number, it tells me that the card # is invalid. And there doesn't appear to be an actual account that has been set-up as I get an error message when trying to log-in to My Account. I sent a private message more than 24 hours ago to @CS_Agent but have yet to hear back! This is really frustrating. Let me know if you have any advice.
Joining Public
06-28-2019 08:49 PM - edited 06-28-2019 08:53 PM
@ChuckYeahI would recommend do account activation late at night during off hours. Make sure the browser (ideally on a computer) is freshly restarted, Javascript and cookie enabled and free of plug ins.
Remember Birth date is not mandatory to be true (also take screenshots).. also remember the PIN.
Have a spare credit card ready, stupid I know, but it is what it is.
Update and reset the phone before hand if possible. Your friend mind as well do a "Marie Kondo"ing of their phones when they move to a new account.
06-28-2019 08:43 PM
No I meant in hindsight. I was afraid to try the activation again so I just waited for the moderator.
If a friend signs up later, should I recommend they try several times or is there a danger in that? Double charging or confusing the system.
Chuck
06-28-2019 08:38 PM
06-28-2019 08:27 PM
I was afraid to try it again. Can you make things worse by trying over and over?
06-28-2019 08:21 PM
@zj1 wrote:Thanks. I actually hadn't put the SIM card into the phone as I assumed that it wasn't activated. I just tried it and it actually works! Now, I just need to figure out how to login to my account...it's still not recognizing my email, even though I received an email from Public Mobile... 😞
06-28-2019 06:44 PM
When you log in make sure the log in email is matched the email in PM system and make sure you type the exact email in. Or you can copy the email address that PM send message to you and paste it into the log in page.
06-28-2019 06:26 PM
06-28-2019 06:25 PM
@zj1 wrote:Hello,
@zj1 When the activation does not complete normally you have to wait for about an hour for that lock to clear. Clear you cache and try again after an hour maybe use incognito mode with your browser.
06-28-2019 06:01 PM
I had the same issue a few days ago and it was frustrating for me to, but I was contacted within 36 hrs and I was up and running in 44.
Short term pain for long term gain, I say!
06-28-2019 05:51 PM
Actually friend of mine had the same problem, she had to wait 30 minutes because the session locked the sim and it repeated 3 or 4 times but eventually it went through even before moderators answered, so I would suggest just try again with a new browser and preferably with a clean cashe
06-28-2019 05:49 PM
It usually takes 48-72 hours for a moderator response depending on workload. There seem to be many people have issues setting up new accounts for the past few days.
06-28-2019 05:48 PM
@zj1 wrote:Hello,
Try using Chrome incognito mode to activate. And since you send private message to moderator team 2 days again, I think you'll get respond from them soon.
06-28-2019 05:44 PM
@zj1 Normally the moderators will reply within 2 days and sometimes up to 3 days if the load is high.
Things to try in the meantime as you wait for moderator:
1. Reboot your phone
2. Try your PM SIM card in another phone to help determine whether hardware issue/setup versus Public mobile service problem
3. Lost/stolen phone trick. Will reset your SIM.p
To report your phone lost/stolen. Login to your account. Choose Plans and Add-ons tab. Then choose Lost/Stolen Phone tab. The choose Suspend Service tab. Logout. Wait few minutes. Login in and report your phone found. Reboot phone.
06-28-2019 05:43 PM
answers can take up to 48 hrs on average.. one of the things you have to put up with for cheaper service..
in the meantime, make sure you have provided all relivant info like SIM IEME, pin etc to save an extra step
jope you get resolved soon
