8 hours ago
Hi,
I got new phone Galaxy S24 Ultra, my sim works fine on old phone but new one cant recognize the card, cant register on network. It says: SIM 1 NOT ALLOWED
7 hours ago
@PK1010 All carriers use eSIM but not all carriers support smart watch /Apple Watch I know Telus does thou . For the public mobile app you get it from the App Store on your phone.
7 hours ago
PM supports eSIM,
You can download Public Mobile app from Google app store.
But why don't you try to call Samsung Canada and see if they can help? And call your seller?
7 hours ago
Where did you get your device? If it's carrier locked it's not a Canadian phone. It's likely the seller knows that it's carrier locked and will likely be blacklisted next. I would return it if at all possible.
7 hours ago
App? where do I get it ?
7 hours ago
do you know who supports esim ?
8 hours ago - last edited 8 hours ago
@PK1010 unlike blacklisting where usually only one IMEI (sim slot) is locked, When a phone is locked, both physical sim and esim are locked. You can spent $5 and try but I doubt it work. So, better to get an unlock code
if you still want to go ahead and test with esim, first, download the app on your new phone. Click Account from the bottom, then click Purchase SIM Card and select eSIM.
Once it confirms your phone is eSIM compatible, click Pay $ and Install and follow the prompt to complete and purchase and install eSIM on your device
8 hours ago
8 hours ago
what about e-sim, i am not sure how it works, i need that for my watch as well, can I have an esim instead of sim card ?
8 hours ago
as said, your code was carrier locked, either Samsung Canada can help or the seller has to contact the carrier where he/she got the phone from to get it unlocked for free
Of course, you can try local mobile store and pay for a carrier unlocked code
8 hours ago
did all that
8 hours ago
@PK1010 Well if phone checks out and it’s not black listed maybe try reseting network settings
8 hours ago
@PK1010 Your phone was carrier locked, something that PM cannot help with
Usually you have to call the carrier where you got the phone from to get it unlocked, but since it is a Samsung, you can try to call Samsung Canada at 1-800-726-7864 for a master unlock code.
8 hours ago
phone is good, original Samsung Galaxy
8 hours ago
IT IS SECOND HAND, BUT WAS HARD RESET
8 hours ago
@PK1010 Is the phone brand new or second hand ? If used first check
Check
