05-19-2021 03:44 PM - edited 01-06-2022 02:06 AM
My phone previous service provide is Roger, can enroll your service. if its $25 + tax for unlimited calling and 1G data?
please email :************************
thanks,
katie
05-27-2021 03:45 PM
Yes you want to activate not register your self serve account that will be created automatically when you activate online. Make sure you clear your browser, reboot your device, open on tab only using secret/incognito mode in firefox, chrome or safari as they work best.
I see you are interested in the $25 plan however if you activate and choose the $35 plan you can also try adding the promocode 2GBBONUS for a 2gb data add on along with your referral code on the 4th page. After activation but before your first renewal you can schedule a plan change on next renewal to the $25 plan. You will recieve a $35 credit for your third month and hopefully you will also keep the 2gb add on despite changing plans. The $10 bonus referral code will appear in your account within 72 hours but most likely the next day.
All told this will net you $10+$35=$45 (+the $2 autopay reward for each month)+ 2gb add on (value=$30)=$75 worth of credits for activating the $35 plan for your first month instead of the $25 plan which nets you $35 in credits +autopay rewards.
05-27-2021 02:07 PM - edited 05-27-2021 02:10 PM
@chenm312 : Click up top ... Activate ...to activate an account. Through that process you can enter the referral code. You could also try using 2GBBONUS promo code if you want a plan cost of $35 or more. Yes you need to use the same email address in the activation process. Edit: Yes you can transfer your number from a different provider through that process.
05-27-2021 02:00 PM
hello,
i register one email address for get 3rd one month free when i active sim card.
but when i use this email address to create account it ask put phone number, but my number not activate momently.
one thing want confirm i need use that email to do activate sim card , during i active sim card, i can assocaited my phone number ( i arleady has phone number) and put refer code to get $10 discount as well?
05-19-2021 06:12 PM - edited 05-19-2021 06:19 PM
The $25 PM plan will be 500mb of data but if you go on AutoPay, there will be an additional 500mb of data totalling 1gb. Unlimited calling with Canada if made in Canada and unlimited texting.
There is a $2 discount/30 days if you enrolled on AutoPay so your bill will be $23.
As noted by @darlicious , there is a Flash Sale for 1 month of free service if you enter your email address for this promotion.
In addition, this is a $10 discount off your bill if you get a referral code from any existing PM member.😉
05-19-2021 05:34 PM
Yes escape rogers....register your email for the promo here.....
https://www.publicmobile.ca/en/on/fs2020
Then read this post......
BTW...its doubtful that a sim card ordered from pm will arrive in time. Go to a retailer to purchase one or ask if they will give it for free if you activate in store if you don't take the CCS bundles offer of a free sim card.
05-19-2021 05:13 PM
@chenm312 : I'm sure it'll be fine. Rogers still operates an older cell technology that the others don't. That's why I asked.
So yes...get a SIM, get a referral code, sign up for the promo, use one of the other promo codes that someone around here can post, activate with all of that, transfer your old Rogers number if you wish, select that plan, pay. Wait for text from Rogers, then insert new SIM into that phone. Incoming calls and texts usually come a little afterwards.
05-19-2021 05:12 PM
iPhone 11 should work here without issue. Make sure it is unlocked.
05-19-2021 05:08 PM
my phone is iphone 11
05-19-2021 03:46 PM
@chenm312 this is an open forum, you might want to remove your email address.
Were you trying to confirm if your previous Rogers phones can be used here on PM? If so, please post the model of the phone and we can try to lookup for you.
05-19-2021 03:46 PM - edited 05-19-2021 03:46 PM
@chenm312 : What exact make/model/submodel phone do you have?
Click Get Started up top to see about getting a SIM or a phone and then activating.
Don't forget to use a referral code to get a $10 credit after activation. Unsolicited ones are against policy here.
05-19-2021 03:44 PM - last edited on 05-19-2021 03:48 PM by CS_Agent
sorry my email is *******************
