11-15-2016 09:36 AM - edited 01-04-2022 06:20 PM
I have 3 lines with a share everything plan from Rogers. I want to port my main number to public mobile and leave the other 2 at Rogers. Can I do this.
02-16-2017 02:06 PM
02-16-2017 01:47 PM
Ported over with no problems. Bye bye Rogers and hello Public Mobile.
02-15-2017 10:18 PM
Do you have permissions to change anything on your rogers corp plan? That maybe an issue. I would just call rogers and ask them about the number you are porting and if will affect the other numbers. They will tell you
11-17-2016 08:06 AM
Just 1 more question this is a corp plan, the port should be the same.
11-16-2016 09:41 AM
11-16-2016 09:40 AM
Just one more question as I have never ported before. So I am only bringing one of my lines to Public Mobile and leaving 2 with Rogers. Should I port my number first (this is the main line with the share everything plan with Rogers) and then the next number in line will take over as the main with Rogers. Is this correct? Thanks for helping a newbie here.
11-16-2016 08:19 AM
11-16-2016 08:19 AM
Great so that means my 2 other lines will not get cancelled by Rogers. That's good to know.
11-15-2016 02:55 PM
I did the same thing.
The main line cost ends up switching to one of the other numbers on the plan and the other Rogers numbers on the account.
11-15-2016 09:37 AM - edited 11-15-2016 09:38 AM
I think you can do this but you should call Rogers and ask them what will happen with the other 2 lines on the account. I assume one of the other 2 lines will have to be set up as the main line.
