08-30-2022 06:05 PM
I bought US roaming on August 19th and drove through NewYork, Pennsylvania, North Carolina, Verginia, West Verginia, Tennessee, Georgia and South Carolina. I didn’t get cellular and data reception anywhere except momentarily couple of times. I am really disappointed and would want refund of money paid. I also advise others to be aware.How do I claim refund.
Add-Ons
09-07-2022 09:49 AM
After going back and forth, I did get a refund through the CSAgent. Thank you all for your comments and help.
08-30-2022 08:12 PM
PM talk roaming isn't good in US because of poor coverage under T-mobile 2G network. You may get local sim or use voip.
08-30-2022 06:19 PM
contact PM support team by private message CS_Agent to remove it thoce Add-ons from your account and them will be credit to your account money back by credit you will see that amount at Available Fund, for next cycle will be taken from there automatically..and how much the remaining of your balance will be taken from your credit card..
08-30-2022 06:08 PM
@pramod did you try to manually connect to AT&T or T-Mobile? if you are only looking for Data connection, a manual connection should work if Automatic fails. But if you have voice roaming, then you can only connect to T-Mobile for its 2G network
But I think you are back in Canada already. No worry, PM is fair and usually will provide refund or partial refund if the roaming service did not work. just open ticket with them:
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
08-30-2022 06:07 PM
hi you can ask a cs agent for a refund or credit ,
1. you can open a ticket through Simon here https://publicmobile.ca/chatbot.
2. alternatively you can private message them here
08-30-2022 06:06 PM
@pramod wrote:I bought US roaming on August 19th and drove through NewYork, Pennsylvania, North Carolina, Verginia, West Verginia, Tennessee, Georgia and South Carolina. I didn’t get cellular and data reception anywhere except momentarily couple of times. I am really disappointed and would want refund of money paid. I also advise others to be aware.How do I claim refund.
Public Mobile can't guarantee the service provided by another network. For consideration for a refund, you'll need to open a ticket to a customer support agent by going to: https://widget.telus.tiia.ai/publicmobile/publicmobile.html
