Roaming
Sparrowe895
Is this plan good to call and text as well as have data in the us..while in the us as well as from the us to canada?   I just want to double check is all.
2 REPLIES 2
hairbag1
@Sparrowe895
you can use this plan while in Canada / Mx and US...just as if you were at home. You can call most any Cdn, US and Mx numbers from anywhere in Canada/US or Mx.
Make sure you enable Roaming in settings to be able to use data.
You'll have best success if the network is AT&T, T-Mobile in USA and while in Mx you can use Telcel, AT&T or Movistar.
BTW...you should edit out your personal info ...maybe just delete that entire picture. Click that little down arrow v on top right corner, to edit your original post.
