Roaming
Gregjc1
Is Roaming available for South America?  If so, how do I ensure that I don't incur Roaming charges?
Chalupa_Batman
Public Mobile only works in Canada and the United States (with the purchase of roaming add on). You can not use your Public Mobile in any other country. If you wish to use cellular services while you’re in another country, you can look at https://www.airalo.com/ for affordable data plans and then download an app like Fongo and pick a local number to where you currently live. They do however charge for texting. TextNow is free calling and texting. You can use both of these VOIP programs via WiFi or on a data only SIM card.
hairbag1
@Gregjc1
if you'll have wifi during your travels...consider downloading the free TextNow app. Using wifi or separately purchased data, you'll be able to send / rec free calls and texts to most any US or Cdn number. Did I mention it's free !
@Gregjc1
PM only has roaming for USA and no roaming at all in any other countries.
and PM is prepaid, so no surprise billing and won't have extra charge at all, unless you pay and buy any addon yourself.
@Gregjc1  No sorry PM only has roaming in the US
