yesterday
I'm about to travel to the u.s. and have the unlimited u.s. wide plan with texing (I've had it for quite a while.
Will I get roaming charges? Can i leave my phone on? Thanks
yesterday - last edited yesterday
You're still roaming when you're in the US, but it's included in your plan so there are no extra charges. You'll want to:
1) Turn Data Roaming ON
2) Set Network Selection to AUTOMATIC
3) Set Preferred Network to 4G/LTE (because roaming on AT&T 5G doesn't work)
yesterday
@Marc_J No you won’t have any extra charges PM is pre paid so no surprises bills you can only use what you have pre paid for . And if you have the CAN/US plan it has roaming built into the plan itself . Just know when you in the US to have data roaming turned on in phone settings . Also put your network to 4G/LTE not 5G and connect to T mobile or AT&T some have said Verizon works to . So be sure to test all 3 and use the one that works best for you
yesterday
there are no roaming charges or any other charges with your plan. Make sure you have a volte enabled cellphone for best talk ability in US.
