2 hours ago
- last edited
2 hours ago
computergeek541
I have a Canada U.S. plan with data and in the fine print it shows I can use data in either country, I am from Canada and currently visiting the U.S. I have to turn on roaming data to use it and it says I may incur extra charges?
2 hours ago
@Dave_72 There are no extra charges since you have the Canada-US plan. You can just leave data roaming on all the time. Since Public Mobile is prepaid if you do something not covered by the plan it simply won't work.
2 hours ago - last edited 2 hours ago
Hey @Dave_72
Just ignore that message. It's a standard greeting everyone gets when they enter the US.
As long as your data calling and text work, everything is fine. Remember one fact. Public Mobile is PREPAID. Meaning you pre pay for your service. You can not be charged after the fact. Make sense?
I've had the Can/US plan in the past. I used it and abused it while in the US with no extra fees ever.
