Roaming to the Caribbean?
edalgaard
Is there any way to use my public mobile phone while vacationing in the Caribbean?
1 REPLY 1
koimr1
Basically - no. PM doesn't have any international roaming other than the United States.
Best bet is either a wifi/forwarding solution like Fongo (if wifi is going to be available everywhere you need it) or purchasing a local or global (like KnowRoaming and similar) SIM card and plan.
