08-17-2022 09:19 AM
I added a roaming add on 3 days ago. It keeps telling me, "no service". in the past it has worked for me, but now it doesn't. I have turned my phone off an on again. It gives me 1 bar on T-Mobile then it disappears and show no service. How can I get a refund for my roaming add on that doesn't work?
Thanks
08-17-2022 09:26 AM
@rcmoodyx3 , the spotty connectivity could be due to specific location. Are you in a major city or in a rural setting?
08-17-2022 09:23 AM - edited 08-17-2022 09:24 AM
@rcmoodyx3 you can definitely ask for a refund or a reverse of the transaction and leave the money in the account for future usage
But first, which addon you have? If it is just data or Data + Text (no voice), you can try to manually connect to AT&T as well
But if voice is part of the add-on , you have to manually connect to T-Mobile and try to use it 2G +LTE network for voice and data
Also, which state and city you are in? You can try again in a different part of the city and see if it connects to T-Mobile
If that still does not work and you are going with the refund, please open ticket with PM support:
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
08-17-2022 09:22 AM
Most likely you will get less and less service in US due to shutdown of 3G network.
It does not hurt to ask for refund due to no service.
To contact CSA-agent, there are 2 methods:
If ticketing does not work very first time, contact agent directly.
- Send a private message to the CSA - agent by clicking Here
Watch for envelope in top right corner. It will show Number of unread emails.
