11-29-2022 11:47 AM
Hello! If I buy Roaming as an Add-on, will it work in Mexico? Or just the US? How can I get roaming (data) in Mexico? Or what do you recommend?
TIA 🙂
3 weeks ago
Thank you for this! I actually thought it was going to be like this but wasn’t exactly sure of the whole change of SIM card 🤪👍
3 weeks ago
One thing that will change is that you will have a Mexican phone number and if you call or text someone they will not know that it is you. For texts, suggest putting your name somewhere in the text. Also you will need to text with the +1 prefix to the area code if you are on cellular service when you text.
12-04-2022 11:30 PM
thank you very much!! I truly appreciate it
12-04-2022 10:50 PM
Not a stupid question at all. As long as your PM plan is up to date and Active....you just put the PM sim in the phone and you're back in business when you get home.
12-04-2022 10:45 PM
Hi,I have a question probably stupid, if I purchase a Mexican SIM card I just put it in my phone and everything stays the same,I can just make calls and texts and then when I get back to BC I just put my original public mobile SIM card back in? Sorry but I’m really not very up to date with all this stuff
12-04-2022 10:43 PM
Hi I have a question probably stupid, if I purchase a Mexican SIM card I just put it in my phone and everything stays the same,I can just make calls and texts and then when I get back to BC I just put my original public mobile SIM card back in? Sorry but I’m really not very up to date with all this stuff
11-29-2022 01:35 PM
Thank you!
11-29-2022 12:01 PM - edited 11-29-2022 12:01 PM
My personal preference is to download free voip app like TextNow. You can select a free Cdn number. You can send / receive free calls and texts using wifi. Most cafes, resorts and hotels have free wifi, you might have to ask for the password.
If you're going for a few weeks, I'd suggest you pick up a local sim card and a cheap 30 day plan...The one that I've used is Telcel Amigo Sin Limites...for about $20Cdn. I can call / text MX, US and Canada for 30 days. Plus I got about 3 Gb's of data.
They do have inexpensive pay and toss phones at most OXXO or KIOSKO stores (similar to our 7-11 stores)
11-29-2022 11:58 AM
PM only roams in US (and arguably not that well). You could either look at a Mexican SIM, or possibly one of the US carriers with roaming in Mexico (for example, the more expensive TMobile prepaid plans include some roaming in Canada and Mexico).
11-29-2022 11:50 AM
@tdotdee hi you will need a local sim as there are no roaming addons for mexico with Public
