03-06-2023
10:03 AM
03-08-2023
12:39 AM
Dunkman
I am an Ontario customer ,
1. Will my phone be working in Calgary?
2. what to do for US roaming?
thanks
12-09-2023 04:23 AM
03-06-2023 10:12 AM
You will need to purchase a 15 day US roaming add on for your phone to work in the United States. At the present time, due to the decommissioning of the 3G network in the USA, Public mobile talk service in the US is hit and miss. PM uses the T mobile 2G network for talk. That coverage varies depending on your location.
Here is some more information:
https://www.publicmobile.ca/en/on/get-help/articles/us-roaming
03-06-2023 10:10 AM
@tkpanchal wrote:I am an Ontario customer ,
In market plans are for use within all of Canada, so yes you can use it in Calgary. Unless you are on an old grandfathered provincial plan, is this your situation?
If you are traveling in the USA, you will require to purchase a Roaming data addon for services, exception is incoming texts those should still be received without additional addons.
Get Help Article for Roaming and things for reference:
Public mobile talk is hit and miss these days because of the decommissioning of the 3G Network in the USA. PM roaming talk depends on the 2G T mobile network which has unreliable coverage in the USA. Data and text should work fine.
thanks
@tkpanchal see above
03-06-2023 10:08 AM - edited 03-06-2023 10:09 AM
You have service Canada wide. Check out the US roaming packages available and use the search bar to see how to add these and when.
03-06-2023 10:08 AM
Your PM plan will work anyway in Canada as long as there is coverage.
USA Roaming is used while in the USA and you need to connect to the T-Mobile network to work.
