10-12-2019 01:45 PM - edited 01-05-2022 07:32 AM
I purchased a 250 MB roaming data plan for US. It did not work at the begining, so I purchased a US call 200 min US and Canada Long Distance add-on. By the end, I findnally got the roaming data to work, but the 200 min US and Canada Long Distance is still not working, I cannot make calls at all and I do not need that any more. Can I cancel this add on and add this $8 as a credit? Thanks!
10-12-2019 02:01 PM - edited 10-12-2019 02:02 PM
@cavemantoronto wrote:
@scarlett_dong wrote:I purchased a 250 MB roaming data plan for US. It did not work at the begining, so I purchased a US call 200 min US and Canada Long Distance add-on. By the end, I findnally got the roaming data to work, but the 200 min US and Canada Long Distance is still not working, I cannot make calls at all and I do not need that any more. Can I cancel this add on and add this $8 as a credit? Thanks!
200 minutes is only for calling if you are in Canada. The roaming add on is unlimited talk.
Yes I agree with @Dunkman and chances are you will not get a refund. Just save the US calling add on for future use as it won't expire til used up. You may use it to call Americans anyhow and while a little more expensive than the $5/500 min add on for canada if You downgrade to the $15 plan at some point you can use it to supplement your outgoing calling then.
10-12-2019 01:53 PM
10-12-2019 01:51 PM
