PUK CODE
05-19-2019 03:25 AM - edited 01-05-2022 07:32 AM
HELLO,
HOW ARE WE ABLE TO GET THE 'PUK' CODE FOR THE SIM I HAVE FOR MY PUBLIC MOBILE ACCOUNT?
Service
07-22-2019 01:16 PM
Pprivate message a moderator here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
07-22-2019 01:13 PM
My phone needs the SIM card puk code, I already have the previous carrier unlock code,
but the phone needs the SIM card puk, please help
05-19-2019 05:45 PM
@bnaugler24 wrote:HELLO,
The very first thing you will need to do is determine which type of code that you need.
The PUK of the sim card itself is a security measure and a code that is need if you enter the sim card's secuirty PIN too many times. If this is what you need, then only Public Mobiile's moderators can give you that. Moderators can be contacted through this link: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437 .
Please note that code is not normally needed unless someone turned on your sim card's security features and then entered the incorrect sim card PIN multiple times incorrectly.
If your phone is askking for the "Sim network unlock PUK", this means that you phone is locked to a different carrier. This would meant hat the "Sim network unlock PIN" incorrectly multiple times. These codes are soemthing that only the original carrier of the phone or the phone's manufactuer can provided. Public Mobile cannot help you with either of these. The "Sim unlock network PIN" is the actual code that you would need to make a phone unlocked so that a Public Mobile sim card can be used, but the "Sim network unlock PUK" would first need to be used to re-enable the ability to network unlock the device if the phone is prompting you for that.
Please realize that these codes are completely different things, and it's important to know which you need.
05-19-2019 04:41 AM
05-19-2019 03:51 AM
Samsung is giving unlock codes for free :
- Start a live chat session from Samsung's Contact Us page: http://www.samsung.com/ca/info/contactus.html?CID=AFL-hq-mul-0813-11000170
- Inform the rep that you would like to unlock your phone and provide the IMEI & Carrier info
- In a few (2+) days, you will get the unlock code via email.
05-19-2019 03:49 AM - edited 05-19-2019 06:21 AM
If you had a previous provider you need to contact your old provider to unlock your phone. If you have a Samsung phone, you could contact Samsung for a puk code.
05-19-2019 03:37 AM
Did you switch from another provider or do you have a Samsung phone ?
