05-30-2023 05:14 PM
Hey
I was advised I switched to the new point system, I didn't. I'm now losing my loyalty & pre-authorized payment rewards. That's $6 per month.
Does anyone know how to correct Public Mobile error?
Thx
05-30-2023 05:36 PM
@7227 Your welcome , best of luck
05-30-2023 05:33 PM
Thank you for the help
05-30-2023 05:31 PM
Thank you
05-30-2023 05:26 PM
HI @7227 from what we know, PM won't force people on new rewards, you much have changed by mistake. Sorry, this cannot be rolled back
yes, if you really want to confirm when you changed over, please submit ticket with CS agent , but you really cannot change back to the old system:
05-30-2023 05:26 PM
@7227 Some people have accidentally switched over to them by mistake … even then unfortunately there’s no reversing the situation so no point in even contacting support but here the link
05-30-2023 05:22 PM
PM is undergoing a painful "upgrade"...could be you rec'd that message in err unless you actually did opt for Points.
Log in on a laptop, Rewards > Rewards History to see past rewards summary.
05-30-2023 05:22 PM
Hi
It's showing I'm on the new rewards system.
I didn't authorize this, I was happy with the old $ rewards.
Any idea how to connect with support if that even exist?
Thx
05-30-2023 05:16 PM - edited 05-30-2023 05:17 PM
@7227 If you switched to points from old rewards , you cannot go back to old rewards sorry
Add check your rewards portal see if your on points or $ rewards
