Rewards
johnnycake
If I change my plan, downgrade it, will I lost my rewards
johnnycake
Thanks!
johnnycake
Thanks everyone. Never expected community responses to be so quick and so many.
Hi @johnnycake Generally no change to reward
But if you are on  new rewards system, then the 5% Public points will of course be less
And any data bonus from Activation will be gone with any plan change
LeePublic
@johnnycake No, the plan and rewards websites are separate, so you can change your plans without losing the grandfathered rewards program.
hairbag1
Nope...just don't voluntarily opt out of Rewards...ever.
