Rewards
06-25-2024 04:37 AM
When I go to look at my rewards page all I get is a blank screen. I have waited up to 5 mins with no response. Do I need to do something else besides clicking on the link?
My Account
Rewards
07-08-2024 02:59 AM
Hello,
You can try below steps -
- Clear your browser cache and cookies.
- Use a different browser or device.
- Disable any browser extensions.
If it still doesn't work, contact Public Mobile support.
Hope this helps!😊
06-25-2024 09:56 AM
Did you try the PM app? It seems to work for me rather than the website.
06-25-2024 09:24 AM
06-25-2024 06:26 AM
Do you click on the link in the pop up? I get blank page when I do that too. Instead use the 3 horizontal lines at the top left or the arrow at the bottom right ( depending on your browser) that brings up the menu. Then click on rewards. That brings up the rewards page with a link to your rewards account that should work for you.
