Rewards
MelL07
Do you lose your rewards if you change your plan?
hi @MelL07 are you on the old system??
@MelL07  They won’t be unfortunately. With points system it will basically cost you $60 more a year . Thumbs down 👎
MelL07
Oh...! I liked the loyalty, autopay rewards. I hope the point system will be as interesting!
Yummy
You will only lose your loyalty Data reward if you downgrade your plan.
All other rewards stay until May when we all switch to points. Then no more loyalty, autopay $ rewards. Referral rewards will be 'paid' in points and stay as is (5 referral used to be $5 now it will be 5 points).
hi @MelL07 generally you won't loss rewards if you change plan
but if you recently get a 150 days special data add-on, then a plan change to lower value will loss it.  But that is only for those still on legacy rewards. If you are in Public points rewards, them it does not apply to you
@MelL07  If you downgrade your plan yes you will lose the bonus data add on unfortunately
