04-07-2024
07:43 PM
04-07-2024
08:16 PM
computergeek541
I have an activation that keeps referring to esim without the option to select physical sim, I have been going in circles for that past 8 hours, support agent has not helped
04-07-2024 07:57 PM
submit ticket with support to fix . using the chat bubble bottom right of screen
If that doesn’t work you can always send direct private message to support .
send a private message To CS_Agents
04-07-2024 07:54 PM
hi @ChrisStep1442 which step you are at?? you are using the app ? if you pasted step 2 or 3, it is too late to make the change. If so, ask agent to help.
please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
