Rewards
Jackie_kelleher
Do you have to switch to the new rewards program? What is the advantage? Will it be cheaper?
13 REPLIES 13
Jackie_kelleher
Thanks for the info, seems like I have more work to do to earn rewards
Jackie_kelleher
that seems like work lol
Jackie_kelleher
I too am having difficulty figuring this out, don't make it easy
Jackie_kelleher
Math is fun so are deals, not sure this will be a deal
Jackie_kelleher
Thanks for the info
ninjastar
You have no choice. You can't say no. Nope, not cheaper. If you were on the old plans, it'll be more expensive.
Ingme
Oh, okay, that's a different way of looking at it. Another way is, on the $15 plan, the rewards drops from $24 to $9 or just over a 62% reduction. Or another way, almost a 10% increase in the monthly cost.
And that's not even including the drop in loyalty rewards which has a much larger impact. Huh, math is fun.
@Ingme I meant 5% in point is more than half a month of saving every year
Ingme
Perhaps I still don't understand this new conversion but how is the new 5% reward more than half a month saving?
hairbag1
@Jackie_kelleher
once you've amassed at least 15 "points", you'll have to manually apply them to renewal or whatever else you wish to spend 'em on. It's not done automatically for you.
Dunkman
@Jackie_kelleher
Yes, you will have to mandatory switch to new rewards points program starting sometime in May.  It will be automatically done.
There is really no advantage.  For legacy customers, your plan will be more expensive after the change.  You will lose the $2/month autopay and up to $5/month loyalty rewards.  The friend rewards/points will remain the same.  You will get 5% back in points for plan payments.  Instead of $5/month of loyalty rewards, customers will get once a year of 10 points loyalty on the anniversary date of sign in.
@Jackie_kelleher starting May , all accounts on the legacy rewards will be different
Can't deny, changes to any new rewards programs are usually less advantageous to consumers. But on the bright side, we are still saving 5% in points which no other provider offer this saving. 5% is more than half a month saving
hairbag1
@Jackie_kelleher
starting this May, PM will discontinue the REwrads program and all customers, new & old will get Points instead.
