03-15-2021 06:37 PM - edited 01-06-2022 02:18 AM
Hi all,
I went through a sim swap fraud last month, in which I temporarily deactivated/suspended my account for a few hours. I see that the rewards are still on my account, but they weren't applied on my most recent cell phone bill. Does anyone have any insight on this?
Is the rewards not being applied issue related to the temporary suspension of my account? Is this an error or working as intended? Will my rewards be applied for future bills?
Thanks in advance!
03-23-2021 04:43 AM
This a glitch that was briefly fixed last year but returned last fall. If you use the lost/stolen feature while active ( vs using it when suspended to force the system to take your payment) will result in your rewards not being applied upon renewal. However this is not the true intention of the system. The system was set up to prevent an account that is suspended for non payment from using earned rewards for the forthcoming cycle to pay for and reactivate the new 30 day cycle's plan. But it is not meant to deny the customer the earned rewards. As such when this glitch occurs when using the lost/stolen feature it requires the customer to then contact the moderators and ask for the rewards to be applied manually to the account after renewal/reactivation.
03-16-2021 12:33 AM
@Hexaflexagon wrote:Hi all,
The system is working as intended in the sense that rewards are not supposed to be received if any account is suspended. For some reason, lost/stolen appears to make the system believe that a payment was missed.
As for your question about future renewals, those won't be affected, unless your services are suspended again.
03-15-2021 06:48 PM
03-15-2021 06:46 PM
@Hexaflexagon :If you not getting the rewards you should write to Moderator Team by click white bubble at bottom right or click envelope button in to right.
03-15-2021 06:46 PM
@Hexaflexagon You can contact the moderator team for this. You can simply click on the envelop icon and send to "moderator_team" and state your issue. They will get back to you within two business days.
