Rewards + Subscription Change
sav_salone
I picked a new subscription to kick in September 4th. I still have rewards (not points) on my old plan. Will I still receive those credits once my new plan starts ?
Hollister
@sav_salone
The tax on your account is determined by the area code of your number not the address of where you are living. If you want a number from the province you are currently in you can change it in your account under the profile tab.
Edit: For myself I would just keep the same number instead of going through the hassle of changing it which means you have to tell everyone your new number including 2FA for all your financial services. You can also change your address under the profile tab.
sav_salone
Thank you ! I also have another unrelated question: I moved to a new province so the tax is different but I am unsure how to change my location for my account !
Hollister
@sav_salone
Yes, you are on the legacy rewards system and will continue on that. Plan changes has no affect on your rewards. Just do not change to the point system.
