Reward
Kev2001
I purchased the 10 point Reward for 1000 US calling but my phone will not allow. Restarted phone, when does it come into effect?
Thanks
2 REPLIES 2
hi @Kev2001 check My Account to see if the add-on is there already. It might take as many as 2 days for PM to process
and make sure you cann US with a 1 in front of the 10 digits
if you need to ask support agent to check, please submit a ticket with CS Agent using this Chatbot link:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html  Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can  submit by direct message:
@Kev2001  .should take effect immediately . Since you tried rebooting the phone . I suggest context support to look into what gone wrong
send  a  private message   To CS_Agent
