Reward points
Annoying1
Will my reward points be carried over to a new subscription plan if I change my current plan?
2 REPLIES 2
HALIMACS
Whatever rewards you have earned will remain @Annoying1 , however be aware that the bonus data that was applied may be removed if you are changing to a lower tiered price plan.
@Annoying1 yes.. the points will be there even you change plan
 The points you already earned are yours and won't be affected by plan change.
