Reward, add-ons
Drkasra2020
By mistake redeem reward for 500min Canada wide talk but I have unlimited
i want to cancel
just redeem by mistake a few minutes ago
Quigley
@Drkasra2020
If you just made that mistake . Don't wait too long and reach out to a Customer Support Agent to get that purchase reversed or ask for a credit.
Use the Chatbot Simon to get a service ticket started.
Or send a private message to CS_Agent
HALIMACS
Ask CSA to put purchase price into available funds, @Drkasra2020
This way it can be used toward a future renewal.
  1. Use the ticketing system for a faster response time. Click here and type Customer Support Agent, then select Contact Us, then select Other (or the topic that more closely matches your request).  Click the result which states Click here to submit a ticket and follow the prompts,  or,
  2. Send a private message to the Customer Support Agent by clicking here  You’ll need to be logged into your Community account for the link to work.
Meow
You will have to contact agent and ask for refund.
To Contact CSA-agent; there are 2 methods:
Ticket has to be opened through chatbot - https://widget.telus.tiia.ai/publicmobile/publicmobile.html
If ticketing does not work very first time, contact agent directly.
- Send a private message to the CSA - agent by clicking (Ctrl+)Here
