11-25-2023 08:10 AM - edited 12-03-2023 01:13 PM
I didn't see the text from Rogers before I activated the eSim. I'm trying to keep the old number. From previous posts it looks like I need Public Mobile customer service help but I can't figure out how to access? What is my next step.
At the time of posting I am still within the 90 minute notification time if that makes a difference.
11-25-2023 08:34 AM
Did you turn off the physical sim? Double check your settings. You might have disabled the physical sim when you activated the e-sim. Make sure you don't delete your e-sim. Just turn on the physical one if it's off.
11-25-2023 08:31 AM
Thank you for your reply. Unfortunately the service will no longer allow sending a reply text to that number/it shows as undelivered. Same with the phone number provided for questions.
11-25-2023 08:21 AM
It doesn't matter. Just respond to the text.
