03-19-2023 07:23 PM
Hello... I am having problems signing into my Self-Serve account. This seems to be an ongoing problem with my account as I can see from the message history. I have tried to reset the password a number of times but keep getting a message telling me that it could not be changed at this time. This is after I have green check marks indicating all the fields are filled in correctly. Could you please assist me?
My Account
03-19-2023 07:29 PM
Try using different browser. Try Incognito/private mode. Clear browser’s cache. Try forced refresh. Use computer and not phone to log in.
03-19-2023 07:24 PM
hi @Domgodess you ever try to use Incognito/Private/Secret browser mode?
if you tried and still not working, please submit ticket with PM CS agent
at : https://publicmobile.ca/chatbot.
First type Forgot Login,
