02-26-2023 11:01 AM
Hi there,
I am not able to log in in my account.
I followed the instruction on how to reset but the message was "there was a problem resetting your account, please try again."
Please help me to log in.
Thank you
My Account
02-26-2023 11:11 AM
Hi @janet7
can you try using another device?
or open ticket with CS agent for assitance
at : https://publicmobile.ca/chatbot.
First type Forgot Login,
02-26-2023 11:02 AM
Try to use Incognito mode to reset the password and to login My Account after passoword is reset
if nothing works, please open ticket with PM support
1. Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
Start by typing "Forgot Login Information", then click "Contact Us",, then click "Click here to submit a ticket ↗"
2. if you have problem with Chatbot: Private message CS Agent at:
02-26-2023 11:02 AM
Try using different browser. Try Incognito/private mode. Clear browser’s cache. Try forced refresh. Use computer and not phone to log in.
After changing password wait 20-30 min before trying to log in again.
02-26-2023 11:01 AM
@janet7 Get support to help you re gain access
- Get support by starting a conversation with virtual Chat box /SIMon. Click here
- you can send a private message To CS_Agents by clicking here.
Watch for reply top of page to the
Right ( envelope image )
