Reset password
lcapo64
Nothing works, getting really upset I can't use my
phone.
Hi @lcapo64
if you tried the reset password and didn't work, I think you need to open ticket with CS agent:
at : https://publicmobile.ca/chatbot.
First type Forgot Login,
walker1
@lcapo64
Try logging into your account using a different browser in incognito or private mode instead.
It'll work out better.
dust2dust
Just buy a voucher to cover your plan cost and use 611 to reactivate. Lots of stores sell these vouchers and a couple places online. There's a real time payment option in some stores. Then figure out why your password won't work. That way you'll have service.
Or if you know your 4 digit account pin you can use 611 and the registered credit card to pay. (no 4 digit pin needed for vouchers though)
@lcapo64  firs try loggin in again incognito / private mode first there are cache issues
To reset password https://myaccount.publicmobile.ca/en/forgot-password
if your need further help
Getting help from agent
  • Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to our Agents. Click here to get
Or get help right here in the community
  • Alternatively, you can send a private message to our Agents by clicking here. You’ll need to be logged in to your Community account for the link to work
JK8
@lcapo64
Try again but clear your browser cache first and then open a new browser window in incognito. Chrome or edge works well.
