Reset password
Mrizvi
Hi I need to acces my public mobile account to change my billing info. Kindly help . Its not letting me change password or enter my account. Thanks
14 REPLIES 14
Did you have a credit card problem and maybe the bank refunded charges and maybe one of them was from here?
Mrizvi
Yes I messages to an agent too lets see
@Mrizvi wrote:
I paid through voucher. As it block my credit card .  Now trying to login my account to fix it but its not letting me in
HI @Mrizvi
that's good the service is working, you have time to sort out the login
please work with agent on that
Mrizvi
dust2dust
Are your services working? When did you last pay?
Are you using the upper right link called Sign In and then My Account?
HI @Mrizvi
Incognito, Private or secret mode is special browser mode, you can click the 3 dots or 3 lines on the top right and select New Incognito tab , page (could also be callsed Private or Secret)
You can try to login that way and see if it works.  If still going round in login, submit a ticket with CS agent here
@Mrizvi  You in the PM community with customers like you trying to help
Mrizvi
What is this website?
Mrizvi
No how can I do that? Im public mobile user since last 10 years
HI @Mrizvi
are you using app or browser?
try again using browser with Incognito/Private/Secret mode
@Mrizvi  Tap the didn’t get code option or tap resend code few times . This should give option to send code to email instead .if no luck please submit ticket with support to help you
private message   To CS_Agents click
Mrizvi
Its not even going to that screen . Each time I enter code it goes to login screen again
hairbag1
@Mrizvi
did you get set up with new Eversafe security protocol yet ? That's req'd for access to your account now.
HALIMACS
@Mrizvi  if it is because you can’t receive the code try tapping “didn’t get the code?” and you’ll get the option to send it to your email
