11-04-2022 12:18 AM
Hi,
I changed a SIM card because I travelled and since coming back, everything else except my voicemail is working. I am registering as getting voicemails but when I go to listen it says I am blocked. I have turned my phone on and off, switched data on and off but I haven't had success in getting this resolved. Any ideas or things that have worked for any of you?
11-04-2022 12:38 AM - edited 11-04-2022 12:39 AM
Do you have an iPhone? If so try these instructions from @NDesai on resetting your voicemail access #
Check Current Voicemail Retrieval Number
Program New Voicemail Retrieval Number
11-04-2022 12:34 AM
This did work to access my voicemail and reset my password. I then went on and tried my voicemail from the icon on my phone and still am getting the call failed when I access it from my direct voicemail button but I will try again, it might just take some time to reset.
11-04-2022 12:29 AM
@tolson try to manually call from your phone to any voicemail access number here (start with those in your province and closer to you)
if you found one works, try to program it to the voicemail speed dial
11-04-2022 12:27 AM
Sounds great! I will try that. Thank you
11-04-2022 12:27 AM
I haven't been able to access from a landline but I will try to adjust the shortcut. Thank you!
11-04-2022 12:25 AM
Try resetting your voicemail pin #. You can access it on your profile page in your account.
11-04-2022 12:19 AM
@tolson wrote:Hi,
@tolson can you access the voicemail from landline?
If you can, check your phone Voicemail shortcut key/speed dial to see if the number preset there is correct. (Let us know the type of phone you have and we can walk you through how to check that)
