08-23-2023 01:32 PM
Having gone thru this before on my other line, I require a new eSIM after a failed activation and transfer last night. I will need a new SM-DP+ Address and Activation Code
08-23-2023 02:11 PM
Thanks
08-23-2023 01:58 PM
@AceEvans @If you have been charged already and activation failed please submit ticket with support to help you
private message To CS_Agents click
VVVVV Link below VVVVV
08-23-2023 01:54 PM
...new account Activation with FREE eSim. Original SIM Activation has failed....I require new Address and Activation Code
08-23-2023 01:49 PM
'Buy a Physical SIM Card or Activate e-SIM'
08-23-2023 01:37 PM
but if it is a new activation, you don't need to buy a new eSIM
just try to scan the QR code on your email and try to install once again
if not, submit a ticket with CS agent and they will help:
08-23-2023 01:34 PM - edited 08-23-2023 01:36 PM
@Departuresnow Go to PM app subscription add on page at the bottom of page shop sim option select it and you can select eSIM and install it
Add if you need help from support hers the link
