07-21-2022 09:40 AM
Hi,
I ordered a US 1 Gig July 17, 2022 but I see that there is 0% use. I no longer need this for US travel and I would like to please ask for a refund or can this be converted to a Can 1 Gig add on?
Thank you
07-21-2022 10:01 AM
@djjjlawson why was there 0 use? Were you planning on using it but ended up not needing to use it? Or did you have issues when trying to use data?
07-21-2022 09:52 AM
Usually add-ons are non-refundable. You can always inquire with the agent and you might get refund.
If they are not willing to do try to at least get money back on your PM account (not on CC) so you can use it for next renewal.
07-21-2022 09:43 AM
You bought the add-on but didn't use it ? I doubt you'll get any refund as it was available during your time in US.
07-21-2022 09:42 AM - edited 07-21-2022 10:01 AM
@djjjlawson hi normaly there are no refunds but
you can contact a cs agent
1. you can open a ticket through Simon here https://publicmobile.ca/chatbot.
2. alternatively you can private message them here
