12-13-2023
05:10 PM
12-13-2023
06:08 PM
computergeek541
Hello everyone,
I would like to replace my old sim with a new card and keep my number.
Thank you, Rick
12-13-2023 06:54 PM
@Rick007 Oh right, you were having speed issues I think? Is it working better now with the new sim?
12-13-2023 05:32 PM
Hello Phil,
Last week I was having service issues after upgrading to 4G, after doing tests we still couldn't figure out the issue and I asked Gaby if it could be my original sim card and she said to buy and new sim card and try that.
Thank you for reaching out Phil.
Rick
12-13-2023 05:20 PM
@Rick007 To keep same number and plan , You can SIM card swap the number in your account . Profile page
SIM SWAPPING profile tabs
If you cannot log into your account you can get support to do it for you also
send a private message To CS_Agents
12-13-2023 05:18 PM
@Rick007 Can I ask why you want to change the sim card, does it not work?
12-13-2023 05:18 PM
Hello Statusquo,
Thank you for your reply. I found just as you responded but thank you very much.
Rick
12-13-2023 05:15 PM
You should be able to change your simcard in the profile section in your phone my account @Rick007 and your number will transfer to the new simcard after the change.
