09-11-2023
10:53 AM
10-15-2023
01:01 PM
Dunkman
I have a deactivated phone number associated with my email id. Now, I have bought a new SIM card and created an account. However, it is asking for a verification code sent to the deactivated number. How can I solve this?
09-11-2023 11:44 AM
What was wrong with the first SIM?
09-11-2023 10:59 AM
and if they gives you the Send email option and you can login, then you can change the 2FA phone number yourself. Just go to Profile, Manage EverSafe ID and you can update the phone number there
09-11-2023 10:57 AM - edited 09-11-2023 10:59 AM
@Omar_Faruque , if you are able to get into your new account, edit the ever safe information in the profile tab and associated the updated number there.
09-11-2023 10:56 AM
@Omar_Faruque If your created a new account using same email as before this is causing the issues . Please submit ticket with support to get straighten . You ca use this direct link
send a private message To CS_Agents click
VVVVV Link below VVVVV
09-11-2023 10:55 AM
How deactivated? From another phone dial 1-855-4pu-blic and enter that number and see if it finds it.
09-11-2023 10:54 AM
try to select "didn't recieve code?" and check if sending via email is an option
if not, submit a ticket with CS agent and they will fix it
