Release Phone Number for transfer
Shaunriching
How do i get my phone number released so that I can transfer it to another carrier. I tried today and it said it was locked to public mobile.
@Shaunriching
again, PM does not lock any phone number.  It can be ported as long as the account is active and you provide Fido/Rogers the correct account number.  If you really have trouble porting, you can open ticket with PM support:
1. Open ticket via Chatbot (need access to My Account): At https://widget.telus.tiia.ai/publicmobile/publicmobile.html
    Start by typing "Submit a ticket", then click "Contact Us", then "Other", then "Login" and finally click "Click here to submit a ticket ↗
Shaunriching
Yeah, I tried to move over to Rogers/Fido because they are the only provider with coverage up north where I work. At Fido they got an error message saying my number was ineligible to port and they said it needed to be released by PM. Didn't remove the sim card.
Phil_Adelphus
@Shaunriching   The new provider makes the request to Public Mobile to release the number, you need to leave your PM sim in your phone to receive a text message for your authorization to transfer the number.  You reply YES to PM's text message.  Then the rest is up to the new provider.  Have you gone through all those steps and it didn't work?  Your phone should not be locked to Public Mobile.
@Shaunriching
PM does not lock any phone number. You are free to port out your number
Just make sure the account is active.  Login My Account and go to Profile page and get the account number
On the new carrier, provide them the phone number and PM's account number
Brianna182
You can open a customer service ticket through the chatbot on the lower right
