Registration/ subscription glitch
Daragnok
Registration is stalling at the question about whether you have a SIM card. Is the system down?
8 REPLIES 8
@Daragnok  We happy to hear you got all sorted out . And welcome to PM 🙂
Daragnok
I worked.  Thanks!
@Daragnok wonder if you want to try to create a new email and try activation again. If you are going with that reinstall the app  and clear browser cache for the default browser on your phone first
@Daragnok  You can also try uninstalling the app and reinstall it see if that helps
Daragnok
The Error Code is on the website
@Daragnok  Please submit ticket with support
private message   To CS_Agents click
Daragnok
Thanks for the suggestion.  I tried on the app and Web site. As soon as I log in,  it jumps to that question.  I select I already have a sim and then it hangs on the app and gives me a Error Code: XXX
@Daragnok  If you’re trying on website . Try doing from all from start to finish . You need the all to finish now anyways
