09-20-2022 09:05 PM
I recently got the 10 day US roaming package with data. The cell service was absolutely terrible. Mostly there was no service at all. Occasionally I would get one bar so I suspect my phone settings were correct but there was a problem with the network. When I did connect it was to T Mobile. Last year I had excellent roaming service with the same phone in the same city (NYC). I would like a refund for the roaming package because I was not able to use the service that I paid for.
09-20-2022 10:40 PM
I'm not disagreeing.
09-20-2022 10:39 PM
If it shows as a footnote.....that likely won’t be read. But to be fair the warning should be part of the ordering process....don’t you think? Why pi$$ off customers by not being informative? Especially on those add ons.
09-20-2022 10:19 PM
@CountyDownIeUk- You have to click down into The Fine Print part way down below the add-ons. But it doesn't just show up. Maybe it should. Oh ok so you've selected roaming. You ought to know....
09-20-2022 10:15 PM
Isn’t there a warning about the coverage in USA for the add on. I know I have seen it .... but does one see it, in the buying process??
09-20-2022 09:22 PM
Thanks for your response. I only tried text and data (not voice), so those should have worked if I understand you correctly. I was not able to get service on any network.
09-20-2022 09:08 PM
HI @jjt16 With US 3G shutting down, it has effect on voice but should have no effect on data and text. Did you try both T-Mobile and AT&T? Both should able to provide you the LTE you need for data and text
But , if you were not able to use the service, please open ticket with PM CS agent and they usually will refund without problem:
at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
start by typing : Contact CS Agent
then Click "Contact Us"
then Click "Other"
finally Click "Click here to submit a ticket"
09-20-2022 09:05 PM
open a ticket with PM CS_Agent. at : https://publicmobile.ca/chatbot.
type: Contact Us and Other
Finally Click here to submit a ticket
If you have error submitting a ticket, send a private message to the CS_Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
check inbox(top right corner envelope icon) for response from CS_Agent.
