Referred By A Friend
JayKay27
Hello!
I just transferred my phone number minutes ago to public and was referred by a friend. When I put there referral code and hit submit, I expected it to be part of my profile..but there is no $10 credit and it doesn't show!
What can I do to resolve this issue? Their referral code is xxxxxxxxxxxxxx
Thank you!
@JayKay27
Please note that it is against PM policy to post a referral code on this public community so click on the V in circle and edit out.
Please also note that your $10 credit will be added within 72 hours that will apply to the next month’s bill.
Your friend will receive their 1 point/month after their renewal date.
JayKay27
This helped a lot, I sent them a message just in case and will see in 72 hours : ). Thank you so much!!
JayKay27
Thank you for the help!
@JayKay27  The one time crest should appear in your accounts available funds within 72 hours after activation , if it’s been more then 3 days ask support to ensure it’s been applied correctly
send  a  private message   To CS_Agent
HI @JayKay27
the $10 does not deduct the activation amount on the spot
instead, you will see it on your My Account within 72 hours.  The credit will be used for renewal 30 days later
