02-09-2021 12:03 AM - edited 01-06-2022 02:04 AM
Last two referrals.....no text...but show in My Account. Nothing blocked either. Any one know why?
02-09-2021 12:47 PM
Or isn't there one that says there's so many things that are broken and I don't know where to start?
02-09-2021 10:29 AM
Thanks!! I should have thought that out before I asked.
Isn't there an old saying....If it ain't broke don't fix it?
Is the new saying......If it's broken, don't bother fixing it?
02-09-2021 12:42 AM
These texts were disabled before Christmas. Not only were there incorrect referral confurmation ones but there were double texts going out informing you that you would have one less x twice! I also noticed you wouldn't get one at all if a friend unsuspended.
02-09-2021 12:08 AM
@LurganIeUk wrote:Last two referrals.....no text...but show in My Account. Nothing blocked either. Any one know why?
This is possibly the result of the messages being disabled by Public Mobile. Far too many of these messages were gonig out in error. The messages were inaccurate, so there was really no point to them.
11-28-2020 12:40 PM - edited 01-05-2022 04:17 PM
Solutions:
1. I don’t get a reminder to provide a solution for my OP posts.
.....Is there a setting that I need to update?
2. Just as an FYI @Luddite has advised that you can change a solution in your OP post.
.....The option can be found in the vertical three dots in your Original first post.
3. Is there, in profiles, a spot to find “Posts originated by me”?
